Rob, thanks for posting that info! That's just the verification I needed to trust that I'm getting accurate results and not making it sound worse.
if you installed the v3a8 ran autoeq, could you take down the results and then load v2 and set the eq to that and it be the same?
That's exactaly what I plan to do. Install V3a8 on my spare, run AutoEQ, then copy the settings down and input them by hand into my main player.
And to second Tony's question, what mic did you use? And is it available in the US (since Farnell doesn't seem to ship to the US)? And does it require assembly (because I have no soldering iron)?
And lastly, I *really* wonder if AutoEQ could be used at home to configure the home setup!! Ooh, I can't wait to try. Just ... need ... the mic!
FireFox31
