Does this sound like a faulty mb or some other issue? The mb is PCI Express, but the graphics card is working fine so I assume that isn't a problem.
You should get link state indication regardless of driver situation. So maybe not a bad motherboard per se, but if you have tried different cables, different hub/switchs, it's probably at least a bad ethernet jack/PHY (so a bad mobo for functional/RMA purposes).
Jim
