Mmm.. great(!) info, Peter!
Now, as I seem to recall.. the current running order has a fixed 512-byte overhead, plus something like 12-bytes per FID, so the default of 256KB can handle up to 21802 FIDs, I suppose.
I think the simplest thing to do, for players with lots of "slack" on /dev/hda3, would be to have set_empeg_max_fid move the running order to the end of the partition, sized to match the new max_fid value. The space vacated at the beginning of the partition could then be redistributed among the bookmarks.
Nice, simple, safe, and probably a Good Thing(tm) to have it do.
Right?
EDIT: or maybe just swallow the bookmarks into an expanded running order (up to new max_fid), and relocate the affected bookmarks to the end of the partition.. mm.. I might like this option even more.. mmm..
Edited by mlord (04/03/2005 20:38)
