...they indicate when the track ended earlier than it indicated it would; often, this is the result of a corrupt MP3...
I always suspected that -- more often -- this is the result of whichever version of emplode had a rounding error when calculating the length of the track. Theoretically, if you recalculate the length tag, it'd go away.
The problem is that the "marked" flag should be reserved for the user, or should differentiate between the user setting it, or the player setting it.
roger
