Great news, Peter!
I wonder if the functionality of empeg_set_max_fid_v7 should go in.. or not. I suppose it's easy enough to run once after upgrading.
Meanwhile, Hijack v436 is out. The major changes are:
(1) Slightly cleaned up i2c code (internal protocol for DSP and fan controller).
(2) Fan control logic now continues with setup regardless of errors, and also prints out (serial console) current temperature reading at startup.
(2) Removed "lavatory floor" visual recovery code, since that visual is no longer present as of v3a10.
(3) Removed "previous visual" workaround code for the v3alphas, since this function is now present again as of v3a10 (works great!).
