Okay. Progress!
Now, you are not getting anything out of the rear speakers? Except when you plug the rear RCAs into the front head unit outputs? Do you have the fader controls set correctly? Another thought, make sure (if you are not using a sub) to have the lowpass filter off on the amp. Are you using Y cables? Can you clarify your existing wiring and options on the head unit? Thanks.
Paul Grzelak
