Hmm.... a lot has happened while I was asleep.
If I understand it correctly, clients behind 802.11 wireless bridges cannot use DHCP servers on the other side of the wireless link. If you can assign an IP address to one of these clients manually and have it work, then that's as good as you're going to get. You might be able to set up the AP closest to those clients to provide DHCP addresses, though.
Definitely the clients can use DHCP behind the bridge.
My setup is
192.168.1.1 Main Linux firewall/router
192.168.1.2 Access point (WRT54G)
192.168.1.3 WRT54G running in client bridge mode (fixed IP)
192.168.1.13 MythTV box (DHCPing an address from 192.168.1.1
Hmm.. Maybe some screenshots from the airport's security setup?
