.. soldering to the dsp reset pin and #8 leg of the temperature sensor gave the i2c error unable to get data and would not play music. Understand that i had previously reset the temperature sensor to work again as you have previously outlined and lifted leg #8 to only tie in with the dsp reset pin
Ah well, so much for that idea.
Clever use of building up the solder stack -- small thin wire can also be used in situations like that.
One time, I had to use an Xacto knife to dig away a little plastic from the shell of a chip, to expose some metal of a broken-off pin so that I could attach a small wire to it.
