So I am looking to solder the Temperature Sensor #8 pin to the Lower Right Blue Wire solder location of the attached picture you took. Is this correct?
This other photo shows the correct wire better:
Do I leave the #8 leg of the temperature sensor unsoldered and just wire it to the DSP location?
Yes, that's the idea, anyway. Untested as of yet!
I assume I can follow the same soldering instructions as you gave for the Temperature Sensor fix? ie: 650 degree iron temp.
Yes, maybe even lower -- try 600 degree max, and don't hang around on the pin for more than a few seconds at a time. Breaking the DSP is more serious than the temperature sensor!
