Mark,
So I am looking to solder the Temperature Sensor #8 pin to the Lower Right Blue Wire solder location of the attached picture you took. Is this correct?
Do I leave the #8 leg of the temperature sensor unsoldered and just wire it to the DSP location?
I assume I can follow the same soldering instructions as you gave for the Temperature Sensor fix? ie: 650 degree iron temp.
Thanks
