it didn't take twisting the length of the cable to get it kinked in the first place
Are you sure? Chances are that every time you pick up the handset and put it back you end up twisting it.
That said, in cases where there are two kinks, they are usually opposites of each other. They will almost always cancel each other out when they occupy the same space.
Simple twisting each time you pick up the phone results in tangles like the attached, but doesn't cause the kinks. I don't know what causes those.
