Originally Posted By: Cris
I'm not very good at design and layout, so I asked someone to help me out. The greys are supposed to be low contrast to make sure that the focus is on the pictures, after all that is what is most important on the site.
If you're not supposed to be able to read it, it should be removed completely. If you are supposed to be able to read it, it needs to be higher contrast or it's working as the reverse of what you intended. It becomes distracting because you can see that there's something there but you don't know what it is exactly.
I'm not suggesting putting it in black, but you should definitely darken up the text so someone can easily grab your phone number from it.
