UNTIL I want to add new music and I try to sync with emplode and it times out during the final rebuild, almost like emplode doesn't want to wait for the empeg. Once the progress bar reaches it's end emplode crashes and the sync is ruined and I have to rebuild again via hyperterminal.
Okay, here's a question.
When the "progress bar reaches its end and emplode crashes"... What stage of the synch operation does that happen during? Does it happen during the "rebuilding music databases" stage of the synch operation?
If so, then what do you do? Do you reboot the empeg at that point? If so, that very thing might be the problem. I think what Roger is trying to say is, that if you left the empeg completely alone at that moment, and just let it sit there for a while, it should theoretically finish the database rebuild on its own without emplode's help.
Not sure if that's actually true in practice, but it's worth a try.
