I think I have the same encoder as yours, just the through-hole version. I needed to cut down the shaft as you did as well.
The description says through-hole but that is incorrect and they sent me the surface mount type. No big deal as I just mounted it on the holes. It was actually pretty easy to solder. I can definitely tell the quality is way better than the old one.
I would encourage anyone to get this part number for either type of mounting
Mine sticks up a little farther than before but it doesn’t look bad and I like it better since it is easier to grab.
