I don't know if this makes any difference, but when I used the "xinput_configuration" with the Raspberry Pi, after the calibration of the screen, the screen already worked as it should. In Mint, even after the calibration procedure, it still doesn't work. (the cursor does not follow the movements of my finger, it goes haywire)
Mint probably has a lot more "stuff" installed that the RPi system, which means a lot more stuff that can go wrong. smile
What kernel version does the RPi use? Command: uname -r
And similarly, what version is your Mint using: same command!
