I just fixed a problem almost exactly like this. In my case, it was that the wire had come undone from the first outlet, as the person who installed it was lazy and just poked the wire into the hole in the back of the outlet, rather than using the screws on the side. The outlets were apparently wired like Christmas lights, where if one goes out, everything else down the line goes out. My breakers looked fine as well, and nothing was burnt inside the outlet either. If the outlet is burnt,
here is how to fix it.
