Lifted pin 9, same output. Then, I lifted pin 8 just to be thorough. Still nothing. As a last ditch resort, I pulled the entire chip. Here's a new boot log with the SMC removed:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v518 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Tue Jun 3 14:28:51 EDT 2014
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102293) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
show_message("Hijack v518 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005d80).
empeg RDS driver initialised
RAM disk driver initialized:  16 RAM disks of 4096K size
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0400
ide_data_test: wrote 0xffff read 0x0400
ide_data_test: wrote 0x5555 read 0x0000
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
hda: SAISQNC IZIT@216HACM)00004, ATA DISK drive
hda: SAISQNC IZIT@216HACM)00004, 7559MB w/0kB Cache, CHS=15359/16/63
smc chip id/revision 0x0003
smc_init couldn't find card
Partition check:
 hda: hda1 < hda5 > hda2 hda3 hda4
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...Kernel panic: VFS: Unable to mount root fs on 03:05
The only difference I can see is that the last four IDE tests read the same write values. This is a good thing according to Tony's FAQ, but what exactly does it indicate? At this point, I wonder if it's an issue with the data line on the StrongArm itself. Is there anything else on the parallel bus that utilizes D8-D15? The PDIUSBD12 and CS4231A chips only seem to utilize D0-D7, and they're properly recognized by the kernel. I should really put an oscilloscope on the D10 line and see what (if anything) it does when the unit powers up. I found the expected waveform format in the datasheet.
