Well, please retest with v143 or later, and if still broken, GIVE ME ENOUGH INFORMATION TO HELP YOU, damnit!
It works fine for me, but maybe you have discovered a combination of INFO and VISUALS for which it mucks up. So let me know exactly what state it was in at powerdown, so that I can try the same thing here. Also, I need to know what type of player hardware you have (mk1, mk2, or mk2a) just in case it makes a difference in the solution.
One thing I just noticed while retesting this feature, is that mk2 and mk2a units behave differently -- one will come up in standby (because the "ignition" sense is not active), and the other defaults to non-standby (because ignition sense floats the other way..).
