Hi.
Just trying to see if I understand you correctly:
All you want to do is to replace whatever is in the right "frame" (which is actually a table field containing a table with a single field) with some new content?
There are two ways to achieve this that I know off:
- use javascript and a < div name="" > < /div > part to encapsulate the part you want to replace
- use frames
I would prefer the second solution. Sure, it is slower, and it doesn't necessarily work with all text-based clients (lynx in particular) all that well, but at least it does work with them to some extend. Also, the "slowness" factor isn't _that_ big considering that you probably only want to load some text.
cu,
sven
