If you wanted to grab the XML off the empeg, and combine it with XSLT etc on another machine then hijack could be modified to add an xml output via fid?.xml in the same way that html is output via ?.html
The template file ideas are to keep processing to a minimum on the empeg.
Jazz (List 112, Mk2 42 gig #40. Mk1 4 gig #30. Mk3 1.6 16v)
