Technically the code already exists for the most part. All I need to do is tweak the boot logo code.
But I am a bit afraid of the freedoms in the Image Pan format. If it is hosted on riocar.org, an adult image section shouldn't be too much problem, since all owners of an empeg are most likely old enough. I just don't want to deal with having to implement an easily bypass able age check system.
I'll poke around at the image pan stuff out there (I haven't even tried it yet) and try to make up my mind. The other 2 should be easy, since those are 128x32 anyhow.
And since I haven't payed much attention to it, I need this question answered. Is there a Linux converter for an image to the format the visuals use? If I do go ahead with this, I'd like to offer a direct file download. And I'll probably try to get a logo file creator started, to make it easier once the ability to change logos on the fly from the empeg develops.
