Hi Mike. I'm trying JEmplode out for the first time. Excellent work! It's very full featured. However, the one thing I want to do with it right now is download my MP3's so I can do a massive re-tag and re-organization. I did a test download of one track and it worked, but now when I select Download, nothing happens. It worked once, but now the dialog doesn't even pop up. I checked the status.txt file and I get this exception:
Exception occurred during event dispatching:
java.lang.NullPointerException
at java.io.File.<init>(File.java:180)
at org.jempeg.empeg.emplode.action.DownloadAction.performAction(DownloadAction.java:92)
at org.jempeg.empeg.emplode.action.DownloadAction.actionPerformed(DownloadAction.java:118)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1450)
at javax.swing.AbstractButton$ForwardActionEvents.actionPerformed(AbstractButton.java:1504)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:378)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:250)
at javax.swing.AbstractButton.doClick(AbstractButton.java:279)
at javax.swing.plaf.basic.BasicMenuItemUI$MouseInputHandler.mouseReleased(BasicMenuItemUI.java:886)
at java.awt.Component.processMouseEvent(Component.java:3715)
at java.awt.Component.processEvent(Component.java:3544)
at java.awt.Container.processEvent(Container.java:1164)
at java.awt.Component.dispatchEventImpl(Component.java:2593)
at java.awt.Container.dispatchEventImpl(Container.java:1213)
at java.awt.Component.dispatchEvent(Component.java:2497)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:2451)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:2216)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:2125)
at java.awt.Container.dispatchEventImpl(Container.java:1200)
at java.awt.Window.dispatchEventImpl(Window.java:926)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:339)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:131)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:98)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:85)
I tried restarting JEmplode but no luck. Any idea why I can't download anymore?
