That way he can easily remove the power supply and replace it if it goes bad or whatever.
I can't tell for sure, but with Loren's (much snazzier -- if they're working well he should fab a bunch and sell them!) brackets for ethernet/power, you may be able to remove the power plug. With my La-Z-Boy, approach, it wasn't an option. For one, the hole was a bit tapered, so I had to cut the wire to pass it through. For another. my candidate replacements (two of the Qualcomms) don't have the same plug style, so I'd wind up splicing anyway. And then there's the Shoe Goo! . I'll keep the DC front panel switch so that I can cycle power to the player while docked (an AC switch would also work), but I just may have to think about adding number6's microswitch.
Jim
