The only reason I would keep my factory head unit is if I can get both it and the Empeg to work. I just don't want to give up my radio. I have to get my talk-radio fix every now and then.
If you want to use your existing VW HU and monsoon amp, then there is a blitzsafe adapter that will enable you to use the CD input for the empeg.
Search for jetta in the installation forum, and you should find some useful info.
