#122252 - 22/10/2002 08:28 empeg always restarts with Transient info
skibum
Loc: Swindon, UK
Since loading hijack 300 (was on a <250 version), whenever I start my car, or plug my empeg in at home, it always starts with the info set to transient. Before hijack 300, it started with 'track' which is what I like.
#122253 - 22/10/2002 08:29 Re: empeg always restarts with Transient info [Re: skibum]
genixia
Do you have "restore DC visuals" set in hijack?
#122254 - 22/10/2002 08:37 Re: empeg always restarts with Transient info [Re: skibum]
I would say this is a fix hijack has implemented for a slight bug in 2.0b13. This is correct behaviour.
As genixia says, check "restore DC visuals" in hijack.
#122255 - 22/10/2002 08:38 Re: empeg always restarts with Transient info [Re: genixia]
skibum
Loc: Swindon, UK
yes. restore DC visuals is on
I did have that in the post, but it rejected it. I obviously forgot to add it back in. Sorry.
#122256 - 22/10/2002 08:40 Re: empeg always restarts with Transient info [Re: frog51]
skibum
Loc: Swindon, UK
I'm still using 2.0b11
#122257 - 22/10/2002 09:02 Re: empeg always restarts with Transient info [Re: skibum]
bodybag
Loc: Southern California
This is a known "bug" from 2.0b11. Just switch to b13 and you won't have to deal with it anymore.
Bodybag - So Cal
Not a Whiner any more!!!
#122258 - 22/10/2002 09:11 Re: empeg always restarts with Transient info [Re: skibum]
Anonymous
Unregistered
Yeah I think the old Hijack had a fix for that bug but the new Hijack doesn't, so just upgrade to beta 13.
#122259 - 22/10/2002 09:56 Re: empeg always restarts with Transient info [Re: ]
skibum
Loc: Swindon, UK
Thanks guys. I'll do that later and see what happens.
#122260 - 22/10/2002 11:23 Re: empeg always restarts with Transient info [Re: skibum]
Daria
I'm using b13 and hijack v300, and when i power down in now&next mode it goes back to transient, i noticed. i don't know if it's expected, and i'm not worried about it. i'm using now&next for the duration of building a "heavy rotation" and then it will be back to "line" mode.
#122261 - 22/10/2002 12:13 Re: empeg always restarts with Transient info [Re: Daria]
bodybag
Hijack may be your problem if you're running b13 and still having the transient mode come up on startup. In a previous thread (I couldn't find it, Sorry), it was mentioned that the transient on startup was a bug of 2.0b11. When I switched to 2.0b13 it went away, but I don't run Hijack on my players.
Bodybag - So Cal
#122262 - 28/10/2002 10:19 Re: empeg always restarts with Transient info [Re: bodybag]
skibum
Loc: Swindon, UK
Well I'm on b13 and hijack 300 and now the problem is slightly different. When the player starts it comes up with info 'line'. Then a few seconds later a message appears saying 'info off'.
I've got hijack restore dc/visuals set to enabled, visuals off and info set to track (which is what I like).
Any ideas?
#122263 - 28/10/2002 10:37 Re: empeg always restarts with Transient info [Re: skibum]
If you like Info:Track, then DISABLE the restore/dc visuals feature. Its purpose is to make Info:Track go away.
