#163830 - 02/06/2003 15:38 Error: Could not connect socket
cloud7
Loc: Switzerland
HI Empeg Freaks! ;-)
I have a Problem with my Empeg Mark 2 when I try to connect it over ethernet:
I can see the Player in Emplode, but when I click it, I get a Error Message: "Could not connect socket"
-This wasn't everytime so, I could easaly access my Empeg over Ethernet with Emplode and JEmplode! -And now none of them works.
I have also tried it on another OS an get the same error...
I _can_ also access the empeg on ethernet over FTP and WWW, so it can hardly be a problem with the hardware of the empeg...?
But what can it else be? And most important: How can I fix it?!
Of course I checked the settings and Network Broadcast is on; the same error occurs, when I enter the IP adress directly...
Edited by cloud7 (02/06/2003 15:40)
#163831 - 02/06/2003 16:29 Re: Error: Could not connect socket [Re: cloud7]
Sounds like a firewall (or firewall software) is getting in the way, and blocking the necessary ports.
#163832 - 02/06/2003 16:38 Re: Error: Could not connect socket [Re: cloud7]
Show us the config.ini file from the player..
#163833 - 03/06/2003 07:02 Re: Error: Could not connect socket [Re: mlord]
cloud7
Loc: Switzerland
Hi MLord!
Here's my config.ini:
[synchronise]
seq_num=40
[Options]
Name=empeg
[User Info]
Email=hidden
Phone=hidden
Name=Steven Varco
[hush]
hushpercent=20
[display]
visual_names=1
caching=0
[volumecap]
enabled=0
[kenwood]
disabled=0
[ramp]
disabled=0
[menu]
quit=1
sort_playlist=1
[controls]
stalk_side=none
[tuner]
region=europe
[sense]
muteaction=0
mute=-1
[power]
off_timeout=20000
[aux]
source=
title=
artist=
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
count=0
[VisualFavourites_FM]
count=0
[hijack]
;@WORK disable_emplode=1
;@WORK kftpd_password=xxxxxx
;@WORK khttpd_files=1
;@WORK khttpd_commands=1
Edited by cloud7 (03/06/2003 07:07)
#163834 - 03/06/2003 07:05 Re: Error: Could not connect socket [Re: mlord]
cloud7
Loc: Switzerland
Hi Toni!
I have made no changes to my System Configuration and then tried on a new, clean OS installation without any Firewall or Firewall Software in the Network... :-(
#163835 - 03/06/2003 08:04 Re: Error: Could not connect socket [Re: cloud7]
If you have it set for "Work" mode (instead of "Home" -- Hijack menu), then..
#163836 - 03/06/2003 09:59 Re: Error: Could not connect socket [Re: mlord]
cloud7
Loc: Switzerland
D'OH! -Thats right what it was...
And I wondered all the time and used the slow USB connection instead...
Anyway, thanks a lot for your hint! ;-)
Edited by cloud7 (03/06/2003 10:00)
#163837 - 03/06/2003 10:18 Re: Error: Could not connect socket [Re: cloud7]
Good! I figured that was what it must be.
