#174808 - 11/08/2003 19:21 Can I use ir translate to make the knob FF and RW
Can I use ir translate to make twisting the know FF and RW like a jog shuttle.
#174809 - 11/08/2003 19:25 Re: Can I use ir translate to make the knob FF and RW [Re: msaeger]
robricc
In the seek tool the knob causes fast forward and reverse.
EDIT: Sorry to not answer your question, but I think you could do that.
Edited by robricc (11/08/2003 19:25)
#174810 - 11/08/2003 19:38 Re: Can I use ir translate to make the knob FF and RW [Re: robricc]
Thanks but I think that only works if the track has been played through once. I want to use it for when I listen to shows I have recorded from the radio and I will only listen to those once.
I want to do it because when I FF for a long time many times I will hit a bump and my finger will come off the button and I end up skipping the track and having to start over again.
#174811 - 11/08/2003 19:39 Re: Can I use ir translate to make the knob FF and RW [Re: msaeger]
robricc
I'm almost positive that's not the case.
#174812 - 11/08/2003 19:46 Re: Can I use ir translate to make the knob FF and RW [Re: msaeger]
Just tested it. Works fine even if the track hasn't been played through before. You don't get the visual benefit of the profile graphic, but the knob twist still works. Remember you have to press the knob to go into "twist" mode.
#174813 - 11/08/2003 19:58 Re: Can I use ir translate to make the knob FF and RW [Re: tfabris]
I tried it before replying to Rob and it didn't seem like it worked on an unplayed track I think it's because the doesn't FF much at a time.
I would definitely be better if I could make it FF like when I hold down the right button.
