#176204 - 21/08/2003 16:45 Power supply in Australia
MattV
Does anybody know where to get a power supply compatible with the Mark 2 player in Australia? 12 V / 1 Amp is not sufficient for a player with two HDDs...
#176205 - 22/08/2003 05:36 Re: Power supply in Australia [Re: MattV]
pedrohoon
Matt,
This one from Dick Smith may work although I have had no experience with it. Otherwise you will have to go for a regulated bench-top power supply such as This one.
Peter.
#176206 - 22/08/2003 17:54 Re: Power supply in Australia [Re: pedrohoon]
MattV
Thanks Peter.
I can't find one that has the right specs, either. I will post a message in the technical section, asking if anyone has succesfully used a power supply with the same spec as the one you linked.
#176207 - 22/08/2003 20:55 Re: Power supply in Australia [Re: MattV]
MattV
I have acquired the linked DSE M9544 supply. It initially seems to work without issue, I'll update this entry if I have any problem with it.
#176208 - 23/08/2003 05:22 Hey Matt [Re: MattV]
Blipman
Loc: Melbourne, Australia
I took the original power supply to Jaycar and said "gimme one of these thanks" and they read all the info off the side of the converter and found an equivalent that will work in Australia. You shouldn't have too many problems. I might have also brought in the manual which has all the power specs, can't remember.
Ben (Melbourne )
Edited by Blipman (23/08/2003 05:25)
#176209 - 27/08/2003 00:28 Re: Power supply in Australia [Re: MattV]
What a monster!
A Jaycar MP3130 (mentioned here) is much better. It's a switchmode so much much smaller and cheaper ($32.95). I have 3 of these and a 2 drive (30+40GB) machine and they have worked faultlessly.
If you can, I'd take the DSE one back and get the MP3130. As long as you have the box and receipt, they should take it back (I worked at DSE for 4 years during uni)
