#177172 - 28/08/2003 02:41 Control 2 riocars w/ 1 PC ?
pupvogel
Loc: Hamburg, Germany
I'd like to open 2 emplode-sessions simultaneously, so that I can control 2 riocars from one PC at the same time.
Is there a way to run emplode more than once, to establish several connections ?
#177173 - 28/08/2003 04:00 Re: Control 2 riocars w/ 1 PC ? [Re: pupvogel]
No.
#177174 - 28/08/2003 04:19 Re: Control 2 riocars w/ 1 PC ? [Re: Roger]
juenk
Loc: Waardenburg, The Netherlands
How about running an emplode and jemplode session on the same PC? (Didn't try it yet..)
Jelle
Empeg M2A Blue # 010101908 80Gb
Empeg M2A Blue # 030102771 with backlight buttons - Need repair (IDE cable connection on main board) - volunteers?
#177175 - 28/08/2003 06:48 Re: Control 2 riocars w/ 1 PC ? [Re: juenk]
That ought to work. There's nothing technically stopping you, just that we couldn't be sure you wouldn't try to connect twice to the same player -- each copy of emplode might have a different idea of what's in the database. So emplode prevents multiple copies running.
Each instance only connects to a single player because otherwise, people would want drag and drop between them, and emplode doesn't support that.
#177176 - 28/08/2003 08:27 Re: Control 2 riocars w/ 1 PC ? [Re: Roger]
Ezekiel
Loc: NH USA
Roger,
Idle curiosity, but how is connecting to 1 empeg from 2 pc's at the same time handled?
-Zeke
WWFSMD?
#177177 - 28/08/2003 08:47 Re: Control 2 riocars w/ 1 PC ? [Re: Ezekiel]
Sequence number in the config file.
#177178 - 28/08/2003 08:48 Re: Control 2 riocars w/ 1 PC ? [Re: Ezekiel]
There is a sequence number that is kept by the player. The first emplode to connect would basically "lock out" changes from subsequent emplode sessions.
Edit: damn... too slow... gettin' old...
Edited by pgrzelak (28/08/2003 08:48)
#177179 - 28/08/2003 08:58 Re: Control 2 riocars w/ 1 PC ? [Re: tman]
Ezekiel
Loc: NH USA
Cool, thanks guys! -Zeke
WWFSMD?
#177180 - 28/08/2003 09:28 Re: Control 2 riocars w/ 1 PC ? [Re: Ezekiel]
The Rio Central added some stuff to the protocol to handle multiple connections at the Central end -- it'll reject the second connection attempt.
The car player doesn't use it, IIRC.
#177181 - 28/08/2003 09:31 Re: Control 2 riocars w/ 1 PC ? [Re: pgrzelak]
This is absolutely correct, but to clarify: what it does is reject the changes from the second session. You can still connect. It only complains when you hit the Synchronise button.
