#209239 - 14/03/2004 10:18 XM PCR?
sharper3
Has anyone considered writing software to control the XM PCR through the Empeg? Possibly expand its features past just playing to Tivo-like capabilities - it stores a song as it plays (as well as its information) and if you like it you can just select save and it saves it for future playback. Just an idea.
#209240 - 14/03/2004 15:21 Re: XM PCR? [Re: sharper3]
sharper3
45 views and no replys? Is this something people would be interested in?
#209241 - 14/03/2004 16:17 Re: XM PCR? [Re: sharper3]
Out of all the empeg owners there are probably less than a dozen that actually write software for the empeg. The majority of us are more than happy with what Hugo and the boys have already provided. As for me, if I had any spare time, i'd put it to better use.
#209242 - 14/03/2004 19:31 Re: XM PCR? [Re: sharper3]
No. Click here and here.
#209243 - 14/03/2004 19:43 Re: XM PCR? [Re: sharper3]
Daria
Sure, if *you* write it.
#209244 - 15/03/2004 08:45 Re: XM PCR? [Re: Daria]
I posted about it here. I'm thinking about tackling this project, but I've never done any programming on the empeg, and it's been since college since I did anything involving serial communication and C (or any programming in C). Basically, I'm saying that there will be a pretty good learning curve and I'm not that speedy to begin with, but I'll probably putter away at it. As soon as I get the clams for the XM PCR unit.
On the plus side, if this does get off the ground, anyone will be able to get a tuner for their empeg for $50 (plus subscription) and patrick can make cooler toys instead of tuners.
#209245 - 15/03/2004 11:26 Re: XM PCR? [Re: JBjorgen]
Well you wouldn't have todo it all from scratch, as there are some third-party scripts available for non M$ OSes.
Of course most of this is mute as the XM PCR connects via the USB port of which we don't have a USB host on the empeg for it to work with.
#209246 - 15/03/2004 13:00 Re: XM PCR? [Re: Phoenix42]
As noted in the other thread:
Fortunately, it is a serial device that is simply using a FTDI serial-usb chip to convert the signal to USB. The pins to grab the serial from are here. We could just connect them up to a MAX232 chip and viola...serial to the empeg.
#209247 - 15/03/2004 14:18 Re: XM PCR? [Re: JBjorgen]
Doh!
/me heads off to get some ketchup.
#209248 - 15/03/2004 14:39 Re: XM PCR? [Re: Phoenix42]
RobotCaleb
moot* (spelling and pronunciation)
as in school and boo
#209249 - 15/03/2004 21:05 Re: XM PCR? [Re: RobotCaleb]
On the otherhand, since this is about how to get XM stuff working through the Empeg, "mute" appears to be an appropriate mispelling.
