#217287 - 28/05/2004 12:22 Is this normal for the handle?
SonicSnoop
Loc: Triangle, VA
When ever I carry the player by the handle it tends to lock in the pulled out position. I have to push it down to get it to go back down. Once it comes out of the locked state the spring pulls it back in. When I first got the player it didnt do this. I have be carrying it by the handle almost every day so im wondering if im wearing it out or something.
#217288 - 28/05/2004 12:46 Re: Is this normal for the handle? [Re: SonicSnoop]
genixia
No it's not normal. There's two things that you can try;
Firstly, with the handle down, look at the sled locking tabs that protrude out of the top. Sometimes they latch up against the case side. With a screwdriver, carefully pry them inwards so they can't do this. It might help to take the fascia off to do this.
The other thing that can cause the handle to stick is the fascia itself. The fascia is mounted to the display board but the handle is mounted to the case, so if the display is not square to the case, the fascia is not square to the handle. Loosen the 4 screws that hold the display board to the case and work the handle a few times. This should help reposition the display board. Don't forget to tighten the screws afterwards.
#217289 - 28/05/2004 13:05 Re: Is this normal for the handle? [Re: genixia]
SonicSnoop
Loc: Triangle, VA
Thanks! I will check those suggestions out!
#217290 - 28/05/2004 15:51 Re: Is this normal for the handle? [Re: SonicSnoop]
Loosen the fascia slightly (four front machine screws), and insert a folded (double thickness) paper currency bill (Euro, US$, etc..) into the gap between the fascia and the handle (one on each side), and then tighten the fasica screws again.
#217291 - 28/05/2004 18:12 Re: Is this normal for the handle? [Re: mlord]
SonicSnoop
Loc: Triangle, VA
Will do. Now that I think about it, It wasnt doing this until after I did my hard drive install so I probobly tightened it too much when I put it back together.
#217292 - 29/05/2004 10:21 Re: Is this normal for the handle? [Re: genixia]
No it's not normal.
Actually, my Mk2 has always been like that. I've tried loosening and tightening things, but nothing ever makes it significantly different until I make the fascia so loose as to flop around. That being said, it's always done this, and hasn't changed over time, so the change may be something to worry about.
#217293 - 29/05/2004 13:26 Re: Is this normal for the handle? [Re: wfaulk]
SonicSnoop
Loc: Triangle, VA
I havent tried loosing it yet but I did notice after close examination that one side of the handle has a very faint white dot where it has i guess been rubbing against the face. So i think that is my problem. Just need to get off my lazy a$$ and find an allen wrench to adjust it..
#217294 - 29/05/2004 16:17 Re: Is this normal for the handle? [Re: SonicSnoop]
mwest
Loc: Ada, Oklahoma
FAQ
Seems they covered the bases... but now you can watch the movie...
-Michael West
#217295 - 29/05/2004 17:03 Re: Is this normal for the handle? [Re: mwest]
SonicSnoop
Loc: Triangle, VA
Oh very nice. Thank you! You know no matter how many times I look thru those Theres always one or two I seem to have missed.
