#219728 - 27/06/2004 12:54 jEmplode 55
mschrag
Loc: Richmond, VA
jEmplode 55 is uploading now to http://www.jempeg.org (give it a couple mins).
Includes:
Fix for soups creating empty playlists for songs that didn't match a search layer
Recursive properties changes are now optional (there is an "OK, and Change Children" button now too)
Error check around SSDPDevice communication for the weird Mac case
#219729 - 27/06/2004 13:15 Re: jEmplode 55 [Re: mschrag]
http://www.jempeg.org redirects to what I believe to be the correct page of http://jempeg.cs.caltech.edu , and I've got every confidence that the files there are right, but the HTML of the page itself still says "54".
Heck, you could probably just edit out the version number from the HTML completely so you never have to update it again.
#219730 - 28/06/2004 07:56 Re: jEmplode 55 [Re: mschrag]
adavidw
Loc: Utah, USA
Oh, so now you're calling me weird, huh?
Well, I'm getting something different now. When I launch jemplode, I get this:
awright-laptop:~ awright$ java -jar ~/download/jemplode.jar
java.net.UnknownHostException: 254.128.0.0.0: 254.128.0.0.0
at java.net.InetAddress.getAllByName0(InetAddress.java:1011)
at java.net.InetAddress.getAllByName0(InetAddress.java:981)
at java.net.InetAddress.getAllByName(InetAddress.java:975)
at java.net.InetAddress.getByName(InetAddress.java:889)
at org.jempeg.empeg.protocol.discovery.NetworkEmpegDiscoverer$BroadcastRunnable.run(NetworkEmpegDiscoverer.java:249)
at java.lang.Thread.run(Thread.java:552)
java.net.UnknownHostException: 254.128.0.0.0.0: 254.128.0.0.0.0
java.net.UnknownHostException: 254.128.0.0.0.0.0: 254.128.0.0.0.0.0
java.net.UnknownHostException: 254.128.0.0.0.0.0.0: 254.128.0.0.0.0.0.0
java.net.UnknownHostException: 254.128.0.0.0.0.0.0.2: 254.128.0.0.0.0.0.0.2
java.net.UnknownHostException: 254.128.0.0.0.0.0.0.2.48: 254.128.0.0.0.0.0.0.2.48
java.net.UnknownHostException: 254.128.0.0.0.0.0.0.2.48.101: 254.128.0.0.0.0.0.0.2.48.101
java.net.UnknownHostException: 254.128.0.0.0.0.0.0.2.48.101.255: 254.128.0.0.0.0.0.0.2.48.101.255
java.net.UnknownHostException: 254.128.0.0.0.0.0.0.2.48.101.255.254: 254.128.0.0.0.0.0.0.2.48.101.255.254
java.net.UnknownHostException: 254.128.0.0.0.0.0.0.2.48.101.255.254.27: 254.128.0.0.0.0.0.0.2.48.101.255.254.27
java.net.UnknownHostException: 254.128.0.0.0.0.0.0.2.48.101.255.254.27.74: 254.128.0.0.0.0.0.0.2.48.101.255.254.27.74
Then, when I click "Ok" in the "Looking for devices" window, I get this:
Failed to create connection factory for device. caused by:
java.net.MalformedURLException: no protocol: unknown
at java.net.URL.<init>(URL.java:537)
at java.net.URL.<init>(URL.java:434)
at java.net.URL.<init>(URL.java:383)
at org.jempeg.protocol.discovery.SSDPDevice.getConnectionFactory(SSDPDevice.java:66)
at org.jempeg.empeg.manager.dialog.ConnectionListModel.getElementAt(ConnectionListModel.java:40)
at javax.swing.plaf.basic.BasicListUI.updateLayoutState(BasicListUI.java:1147)
at javax.swing.plaf.basic.BasicListUI.maybeUpdateLayoutState(BasicListUI.java:1098)
at javax.swing.plaf.basic.BasicListUI.getCellBounds(BasicListUI.java:736)
at javax.swing.plaf.basic.BasicListUI$FocusHandler.repaintCellFocus(BasicListUI.java:1423)
at javax.swing.plaf.basic.BasicListUI$FocusHandler.focusLost(BasicListUI.java:1441)
at apple.laf.AquaListUI$FocusHandler.focusLost(AquaListUI.java:64)
at java.awt.AWTEventMulticaster.focusLost(AWTEventMulticaster.java:172)
at java.awt.Component.processFocusEvent(Component.java:5006)
at java.awt.Component.processEvent(Component.java:4888)
at java.awt.Container.processEvent(Container.java:1569)
at java.awt.Component.dispatchEventImpl(Component.java:3615)
at java.awt.Container.dispatchEventImpl(Container.java:1627)
at java.awt.Component.dispatchEvent(Component.java:3477)
at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1713)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:777)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:497)
at java.awt.Component.dispatchEventImpl(Component.java:3506)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:456)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:234)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:178)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:170)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:100)
Going directly to the IP still doesn't work either.
-Aaron
#219731 - 29/06/2004 10:46 Re: jEmplode 55 [Re: adavidw]
mschrag
Loc: Richmond, VA
Wow .. That IP address builder went into freak mode. OK. This gives me a much better idea of what's going wrong. Thanks.
