#252936 - 30/03/2005 08:49 Plug guts
thinfourth2
okay i bought a new oil pressure gauge and need to know what kind of plug this is on the back of it. It has two external outs for two LEDs for oil pressure or temp. Now in pins 1 and 7 which are the outs there is no crimps to put a female pin in.
It is a 12 pin plug with pins about 2mm square and i need the female part of it so i can get a connection onto the output.
So anyone got any ideas as to what it is and where to look, or even has anyone got two spares hanging around down the back of the sofa.
also need to get macro working on the ixus
#252937 - 30/03/2005 10:24 Re: Plug guts [Re: thinfourth2]
Looks like one of the zillion varieties of Molex connectors. Many electronic component stores stock them (eg. Frys).
#252938 - 30/03/2005 16:15 Re: Plug guts [Re: thinfourth2]
That's almost certainly a molex 'mini-fit jr.' range connector. Farnell part number 151-871. The contacts are separate.
Failing that, it will be a Tyco 'mini universal mate-N-lock', farnell part number 133-670. Again, the contacts are separate.
The molex connector is from the same range as the tuner plug on the empeg dock. Check if it's the same.
Patrick
#252939 - 30/03/2005 16:44 Re: Plug guts [Re: pca]
thinfourth2
i knew it looked familiar pins are exactly the same as the female ones on the empeg sledge.
you ain't got two hanging around have you if not i shall see what i can do, would maplin have them ?
#252940 - 30/03/2005 16:54 Re: Plug guts [Re: thinfourth2]
A quick search of the maplin web site says no.
