#271072 - 29/11/2005 15:07 2 issues: Seek tool and display
edsmiata
Loc: New Jersey
1. when i change the info page to seek tool i am not able to use the control knob to move to a precise portion of the song. i thought this was possible but now i cant do it
2. The display screen sometimes goes batty and changes from full brightness to dimmer and back again...it is not the due to the settings as if i take the RioCar out of the sled and reinstall it sometimes the movement is enough to correct the problem..
any suggestions?
thanks,
Ed
#271073 - 29/11/2005 15:29 Re: 2 issues: Seek tool and display [Re: edsmiata]
robricc
Try pressing the knob in. If you have Hijack installed, I think you will get a pop-up asking what you want to do. Just select SeekTool.
#271074 - 29/11/2005 15:31 Re: 2 issues: Seek tool and display [Re: robricc]
edsmiata
Loc: New Jersey
ahhhh....i dont have Hijack but i dont remember having to press in the knob...but to be honest...the know is getting a bit funky and is most likely in need of replacement...maybe that is the real culprit
#271075 - 29/11/2005 17:04 Re: 2 issues: Seek tool and display [Re: edsmiata]
The seek tool changed between two software versions in regard to what you had to do to seek through the song with the knob. Did you upgrade since the last time you tried?
#271076 - 29/11/2005 17:09 Re: 2 issues: Seek tool and display [Re: wfaulk]
edsmiata
Loc: New Jersey
no...but i have the latest production version
#271077 - 29/11/2005 17:12 Re: 2 issues: Seek tool and display [Re: edsmiata]
You might have a loose wire in your installation, perhaps like this, or your player might need the capacitor fix.
#271078 - 29/11/2005 17:51 Re: 2 issues: Seek tool and display [Re: tfabris]
edsmiata
Loc: New Jersey
Thanks Tony...i have to send this player off the the boys at Eutronics for a tune-up anyways so i will include that on my list!
#271079 - 29/11/2005 17:52 Re: 2 issues: Seek tool and display [Re: edsmiata]
If the problem is due to wiring loom troubles, they are inside your dashboard and Stu isn't going to be much help. Unless you're crating up the Miata...
#271080 - 29/11/2005 17:59 Re: 2 issues: Seek tool and display [Re: tfabris]
edsmiata
Loc: New Jersey
in lieu of a coffin i have requested that i be buried in the miata...it will save space in the ground
#271081 - 30/11/2005 19:13 Re: 2 issues: Seek tool and display [Re: robricc]
edsmiata
Loc: New Jersey
i did exactly that...pressed in the knob and it works fine..but now i dont know why i would want to use this function!!!
#271082 - 30/11/2005 21:05 Re: 2 issues: Seek tool and display [Re: edsmiata]
robricc
I find it's useful for quickly skipping through commercials on recorded radio shows.
#271083 - 02/12/2005 17:37 Re: 2 issues: Seek tool and display [Re: robricc]
edsmiata
Loc: New Jersey
good point!
