Sorry about the unannounced downtime. Due to an intrusion into the server, apache and many other services had to be shut down to prevent any further damage. Basically, an exploit was used against another board on this save server to gain shell access, and the attacker used that to make a fine mess to clean up. The boards seem ok now, but please notify me if anything seems out of place.
As a precaution, the board has been upgraded to 6.5.2 again. This is likely to break a few things as well. I will try to fix what I can, but certain things like the sessions seem to be an ingrained part of the code. This may cause a long post to be lost upon submission, so please copy your text before making a post if it takes more then 5 minutes to compose. That should hopefully avoid any lost messages.
Tom
