#321497 - 17/04/2009 19:33 Apps that reset the focus-stealer registry entries?
Rubbing the EmpegBBS lamp again...
SWMBO has had a longstanding problem on her work PC, in that apps grab focus too frequently and too easily. "TweakUI" I tells her.
But most mornings, she looks in the TweakUI settings, and the "prevent applications from stealing focus" checkbox is mysteriously unchecked again.
I've temporarily put a bandaid on the problem by making a batch file that fixes up the ForegroundFlashCount and ForegroundLockTimeout entries in the system registry, then made a link to that batch file in her Startup group.
That takes care of it at system startup, but I'm guessing there's some application on her system that's being a smartass and messing with those registry entries for its own amusement. I'll bet she still gets the problem anyway, despite the band-aid. Uncle Google says that she's not the only one with this problem, but there aren't any clear solutions out there that I can find.
Anyone else ever run into this problem and solve it?
#321498 - 17/04/2009 19:38 Re: Apps that reset the focus-stealer registry entries? [Re: tfabris]
Leave Process Monitor running in the background somewhere, filtering to the relevant registry keys, and when they change, go inspect the log to see what did it.
#321499 - 17/04/2009 19:40 Re: Apps that reset the focus-stealer registry entries? [Re: tfabris]
Spybot Search and Destroy will tell you when something is attempting to change your registry. Maybe that would help you nail down who the culprit is?
hmm- just found that Spybot isn't the best tool out there...
http://www.techsupportalert.com/best-free-adware-spyware-scumware-remover.htm
#321507 - 17/04/2009 23:02 Re: Apps that reset the focus-stealer registry entries? [Re: wfaulk]
Seconded! You can even set it up to start logging from boot. You will also want to drop filtered events to keep the log from getting overly large.
