#3700 - 14/02/2000 11:06 Hard Boot Command?
Is there a way to hard-boot the player from software? So that it goes through the full bootup procedure as if the power had just been applied?
I'm guessing there's something you could type at the command prompt if you're running the developer image, but what about the consumer image? When I "Q" the consumer image, it soft-boots without going through the full procedure.
-- Tony Fabris -- Empeg #144 --
Caution: Do not look into laser with remaining good eye.
#3701 - 14/02/2000 18:26 Re: Hard Boot Command? [Re: tfabris]
dionysus
Loc: San Francisco, CA
...out of curiosity, why would you want to?
-mark
#3702 - 14/02/2000 19:40 Re: Hard Boot Command? [Re: dionysus]
Among other things, so I can see the bootup screen without having to reach around the back and fiddle with the power plug.
#3703 - 15/02/2000 01:54 Re: Hard Boot Command? [Re: tfabris]
Mark Petersen
Loc: Denmark, Kbh Ø
In Linux you normaly type 'shutdown now' and it is located in /sbin/
Anoter posibility is to set a diffrent runlevel
'init 0' = hallt
'init 1' = singelmode
'init 6' = reboot
Mark
wait for mk III with a USB Host/slave
(USB->Ethernet)(USB->COM 1-8)(USB->You name it)
Mark wait for mk III with a USB Host/slave (USB->GPS)(USB->Bluetooth)(USB->You name it)
