#42632 - 19/10/2001 08:44 VolAdjust ON/OFF using front panel!
I have taken Richard's wonderful voladj feature (automatic volume adjustment) and added support to turn it on/off using the front panel buttons on the player.
This means we can enable/disable the voladj mid-song, to see the before/after effects. I've also added code to default it "on" in the car (battery mode) and "off" at home "non-battery mode". The front panel buttons can still be used to override this in either location, of course.
So.. to turn it off, hold down the BOTTOM button (or the KNOB) and press the LEFT button.
To turn in on, hold down the BOTTOM buttom (or the KNOB) and press the RIGHT button.
I suppose this could be extended considerably, to "hijack" the front panel from the player (while the player is running!), to allow use to add our own custom menus and whatever in a more integrated fashion..
For now, the code is up at: http://rtr.ca/empeg/
Current revision is ".v3." (first two efforts had minor bugs).
Edited by mlord on 19/10/01 06:02 PM.
#42633 - 19/10/2001 09:33 Re: VolAdjust ON/OFF using front panel! [Re: mlord]
Haven't tried it yet, but it's a great idea!
-Tony
MkII #554
#42634 - 19/10/2001 09:42 Re: VolAdjust ON/OFF using front panel! *DELETED* [Re: tonyc]
Post deleted by mlord
#42635 - 19/10/2001 09:52 Re: VolAdjust ON/OFF using front panel! [Re: mlord]
jarredduq
Loc: California, USA
MLord,
You are the man.
#42636 - 19/10/2001 11:24 Re: VolAdjust ON/OFF using front panel! [Re: mlord]
Terminator
Loc: Dallas, TX
Nice hack!
You may want to note on your site that windows users can use tony's logo editor to install the hacked kernel.
Thanks,
Sean
#42637 - 19/10/2001 19:25 Re: VolAdjust ON/OFF using front panel! [Re: mlord]
thanks for the hack !
I also wanted to let you know you have the directions on you site and the bbs post reversed
so can ya tell me which is right :-)
thanks again
32Gig MK2 In 2001 VW Golf TDI
#42638 - 19/10/2001 21:38 Re: VolAdjust ON/OFF using front panel! [Re: msaeger]
>you have the directions on you site and the bbs post reversed.
Ooops.. the bbs postings have it correct, and now the website also has it corrected. LEFT=disable, RIGHT=enable.
Thanks muchly!
See also my new post in GENERAL re: Empeg-Pong!
