#96696 - 30/05/2002 18:55 LED Trouble
MoRoToRiUm
I'm hoping that some one else might have some ideas here. I am modifying my empeg with the Hijack Kernel and LEDs. I have the four LEDs behind the buttons working properly, dim right and everything. Now the trouble are the ones behind the know. Made the board, tested it on a power supply, works fine. Hook it up, works, but not with the dimmer. I've taken it apart a few times and back together to have the same results. Their aren't any shorts or soldier bridges, so I don't know what's up. Maybe after doing it soo many times I fried the Transistor from too much heat. I don't know. If it were fried I don't think it would get any voltage to light the LEDs. ANy other ideas? (Keep in mind I don't see any problems around the Transistor or the board), I'd appreciate it. Thanks again
#96697 - 30/05/2002 21:09 Re: LED Trouble [Re: MoRoToRiUm]
mtempsch
I had the very same problem.
Either the transistor is shot so that it is always on - try measuring across emitter/collector with empeg off. IIRC right and center (top) leg as the board is mounted - should be high (infinite) resistance. Also do a diode check (if your meter has it) across base/emitter and base/collector. Or you do have a solder bridge from the +5V supply pad/trace to the emitter pad/trace (the one going to all LEDs and the tranny). For me the latter was the case - a really really tiny whisker of solder I didn't notice until checking very closely with a big magnifying glass...
#96698 - 31/05/2002 07:39 Re: LED Trouble [Re: MoRoToRiUm]
lopan
Loc: Manassas VA
I had a similar issue... turned out I just had my signal wire soldered to the wrong thing.... is your signal wire from your knob board soldered to the correct leg of your button LED?
Brett 60Gb MK2a with Led's
#96699 - 31/05/2002 08:19 Re: LED Trouble [Re: mtempsch]
genixia
Yeah, I had *exactly* this problem the first time, and it was a solder bridge at the transistor.
Edited by genixia (31/05/2002 08:20)
