Ist there somebody out there who is still interested in OBD-2 and Empeg? As i'm aware Philb has started programming a bit for the Empeg. Maybe just the release of the first code snipplets could give the project a chance.
And for everyone who doesn't know what ODB-2 is:
IIRC the ODB-2-standard is a must in every car since 1995, so I could imaginge that even your car is capable of such a system. This is a bus for diagnistic purposes where some control units (motor, abs, airbag uses different units) are connected like in an ethernet. I don't know much about ODB-2 but I own such a (bought) ODB-2-converter to connect a notebook to a car's ODB-2-Plug. You can build this converter on your own, it should be less expensive than, say, $30, maybe less than $15...
Rolf
Connecting Empeg via Bluetooth or Wireless LAN http://empeg.rowi.net
*** Proud owner of the European Worst Install Trophy 2003 ! ***
RoWi
