I have read the FAQ, and verified that the tuner is hooked up correctly, the cable does not have a crossed line, and the power antenna line is hooked up, and the player is set to United States..
Now, the problem. When I'm using the tuner in FM mode, I get almost no reception. AM works fine, I can get every station that I've tried. When in FM mode, the audio is very quiet, it will show the Tuned in icon. If I turn it up about half way, I can hear the station but has a ton of static. Any ideas?
Thanks,
