I suppose you can get around the problem of having to mount the RAID metadevice instead of hda? by fudging the kernel
It'd be much more likely that one would simply change the /dev/hda? device to point at the device numbers for the metadevice rather than munging the kernel to do it. But it's remotely possible that that wouldn't work, in which case, the kernel intercept most likely would.
