If I set the IP that I want to use under the options tab in emplode, and do a synch, the address is not assigned and emplode just sits there looking for the player.
Are you sure you've assigned it an unused address? Perhaps you've given it an address that's already used on the network, and that's why it refuses to assign the address.
Have you gone through these tips?
