Also, what are the characterisics of the empeg's serial port power?
If you're talking about the serial port on the docking sled, I seem to recall that one of the serial port pins is spliced directly into the Amp Remote wire. So whatever the specs are for the amp remote wire is the same spec as that pin of the serial port.
