Have a look by your A-pillar. If the trim is easily removable then you might find that there is enough space to mount an antenna 'underneath' it so that it isn't blocked by the dash material itself. It worked on my Golf.
IIRC,
Pin 5 is ground.
Pin 4 is Amp Remote (+12V, can handle 1A, I believe)
