it does look pretty straightforward to put together your own "track info" mode to display on one of these. the trick, though, would be how you handling the menuing system. if you don't replicate the existing display as-is, then you won't have an easy way to access menus and get visual feedback.
if you could find a way to display menus and track data, then i think you'd be all set.
--dan.
