With gpsapp I have 2 problems:
1. When gpsapp is running I do no longer receive traffic alerts from the tuner
2. when a route is loaded gpsapp seems to have problems synchronizing with my actual position. When my position is exactly at the starting point of the route I can see the stored route on the empeg display about 5-10m away from my current position, during my travel the current position remains about 5m away from the calculated route but gpsapp does not "close the gap" and sync on the route; the same problem occurs while following a route, gpsapp seems to get easily out of sync between current position and original route (e.g. when a turn is slightly miscalculated) and then goes strictly to the end of the route and does not resync again with my current position, even not if I load the entire route again.
Any idea on this?
Juergen
