Well you know....actually I hadn't. Although there are no other resistors like these, there were two 33k ohm resistors. Here's a picture showing the mystery resistor next to the 33k. I'm now convinced that they are 100k. These two resistors (the mystery ones) are wired in series with the 800 volt g2 high voltage line that feeds the CRT amplifier cards.
No matter where you might be, there you are.
