In reply to:
[standby timeout] is definitely set higher - 30 minutes if i remember correctly.
Are you running the latest player software? Earlier versions had a limit on the allowed timeout values, and would not spend any time in standby if it were exceeded.
While you're troubleshooting, set it to something like 20 seconds. Remember that the value is in milliseconds if you're editing config.ini directly.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
