I'm not a programmer, and I don't know why heck don't supply the program in a finished form!
I thought they did. Isn't that what the Personal Media Agent is? I don't know because I can't get the PMA to function from behind my firewall.
Also, you said you needed an "ID3 maintaining utility"? What is that? Does that mean you have to fill in the tags yourself even after they've been identified?
I think that's only if you're using it in command-line mode under Linux or if you're integrating their code into your own. Isn't the Personal Media Agent supposed to handle that?
___________
